Kicad 9 crashes when opening Kicad 8 schematic
We have been using the attached project schematic successfully with Kicad 8 but it crashes when opened in Kicad 9. The symptoms are similar to those in KiCad 9.0 Lag When Editing Legacy Schematics. The opening progress bar appears for quite a few seconds (showing a bar of just over 50%) after which it and the Kicad window disappear, requiring Kicad to be reoppened.
When we subsequently try openning the project in Kicad 8, we get a message saying that the the project is already open.
Why does the project crash in Kicad 9.0.1?
We think it’s something to do with file TB1.kicad_sch
Attached are the project zip file and the library file that contains all of the symbols that we use.
Workshop-2025-04-25_162942.zip (306.6 KB)
Signalling_Library.kicad_sym (276.4 KB)
Below is the Version Info for Kicad 8 and Kicad 9.
Kicad 8 version Info:
Application: KiCad x64 on x64
Version: 8.0.8, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.0.1
FontConfig 2.15.0
libcurl/8.10.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) UHD Graphics, 4.6.0 - Build 27.20.100.8190
Date: Jan 11 2025 18:59:49
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.10.1-DEV
ngspice: 44
Kicad 9 version Info:
Version: 9.0.1, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Date: Mar 30 2025 01:11:30
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
Because the programmers have placed a bug in the program. It should be presented to users during the easter weekend, but it seems the timing is 4…5 days off.
I have opened a gitlab issue with your project. If you experience such a behaviour (crash) the next time you could open the bug report yourself (kicad–>Help–>report bug. Needs gitlab account). A crash is always a bug and not a user error.
This is because kicad creates lock-files to prevent file modification from different kicad instances. If kicad crashes the lock files remain, so kicad thinks (at the next start, with v8) that the files are still open. Either ignore the warning (in this case you know that the files are not open anymore) or delete the *.lck files in the project directory.
