KiCAD 9 Bus Labeling: spacebar does something wierd
In KiCad version 8 and lower I had no problem creating Group bus labels.
simply create a label and start typing… e.g. GRP{blah blah}.
In KiCad 9, if I create a new label with ‘L’, and select the ‘multiple label input’ ( I have no idea what this means, it wasn’t in KiCad 8) it does not do anything strange when I hit the spacebar and I can create a bus label.
But if I then go back in to edit a bus label the checkbox is missing and I can’t use the spacebar without the drop down appearing.
The bus documentation does not appear to have changed.
KiCad 9.0.3
This looks very similar to a bug that was fixed for 9.0.4 (released very recently): Group bus: entering a space after a group member opens the filter menu and you are unable to complete the bus definition (#21300) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Could you try upgrading and see if this is still happening?
9.0.4 does appear to fix this. Thanks James
