KiCad 9.0 Crashes for fun
So I made the schoolboy error of installing 9.0 whist I had a fully functioning V8.09 :roll_eyes:
It often crashes when opening but eventually stays open after the 3rd attempt.
Worked for a day or so.
Currently crashing and closing every time I try to open the Place Symbols dialog.
Initially it processes the symbol library then the footprint library, it always fails and closes, no warnings, no errors, no logs.
3rd party symbols are a non starter.
Driving me mad.
Is any of this fixed in 9.01?
Thanks
You could try installing 9.0.1 RC1 and see if it fixes your crash. They have fixed a lot of bugs.
I’ve opened a issue for a crash I’m experiencing on 9.0.1 RC1 which causes it to crash in schematic editor every 5 mins. So it may/may not fix your issue, or make it worse :slight_smile:
What operating system are you using? If windows, you could enable crash reporting and then we could see what’s causing these crashes.
Just had a look at the Event Viewer, Looks like at least one of the errors may be caused by KiCad using masses of memory
‘The following programs consumed the most virtual memory: kicad.exe (14000) consumed 2427666432 bytes, eeschema.exe (2204) consumed 2140237824 bytes.’
Another Error - I don’t claim to understand these but maybe they means something to you
- System
|||- Provider
[ Name] Application Error
[ Guid] {a0e9b465-b939-57d7-b27d-95d8e925ff57}|
EventID 1000
Version 0
Level 2
Task 100
Opcode 0
Keywords 0x8000000000000000
|||- TimeCreated
[ SystemTime] 2025-03-23T16:01:07.3011089Z|
EventRecordID 6932
Correlation
|||- Execution
[ ProcessID] 16088
[ ThreadID] 1768|
Channel Application
Computer Redacted
|||- Security
Redacted
- EventData
AppName eeschema.exe
AppVersion 0.0.0.0
AppTimeStamp 00000000
ModuleName unknown
ModuleVersion 0.0.0.0
ModuleTimeStamp 00000000
ExceptionCode c00000fd
FaultingOffset 00007ff96becc6f7
ProcessId 0xc88
ProcessCreationTime 0x1db9c0cb50a2679
AppPath C:\Program Files\KiCad\9.0\bin\eeschema.exe
ModulePath unknown
IntegratorReportId d28f1f19-059f-4ab0-a4b5-e09835b2d657
PackageFullName
PackageRelativeAppId
3rd Error
EventData
AppName kicad.exe
AppVersion 9.0.0.41602
AppTimeStamp 67b60ceb
ModuleName ntdll.dll
ModuleVersion 10.0.22621.4974
ModuleTimeStamp 36d7bcf8
FaultingOffset 00000000000a5387
ProcessId 0x3640
ProcessCreationTime 0x1db9bf347fc2be8
AppPath C:\Program Files\KiCad\9.0\bin\kicad.exe
ModulePath C:\windows\SYSTEM32\ntdll.dll
IntegratorReportId cec37743-5ce4-4343-ada9-3912f93cfa54
PackageFullName
Thanks
Do you have crash reporting enabled? If you do, or if you can, please enable it and let us know your reporting ID if any further crashes occur:
Hi James,
Thanks for the reply, the UID is 1453f60b-3e65-4f88-ad1e-5c8c432e30c6.
There has been a couple of crashes since I turned this on, I will create another in a moment as it is currently easily repeatable.
Thanks
Another update.
The crash did not occur at the expected point this time.
It opened the first Schematic and appeared to be working as expected.
When I opened a second Schematic with the first in the background it crashed on Place Symbol, the crash was a little more dramatic in that it also crashed DWM and went to not responding, I had to manually close this time.
I only found one issue logged to that UID (KICAD-K15), and it’s an assertion failure, not a crash. Are you running a debug build?
Hi Jeff,
Thanks for replying.
I am running the standard stable version 9.0, Not sure what you mean by KICAD-K15?
I have spent the afternoon working through my ERC errors & warnings (noob) and there has been around 8 crashes today - by crash I mean the program has done one of two things, sudden close without warning or an “unhanded exception” that freezes up the entire machine and cannot then be closed without using task manager.
My save’s are working for the most part so not too drastic!
Thanks
Just to add, the current round of “crashing” happens when opening ERC after making an edit but before a save.
If I save and then re open and run ERC - no failure.
Can you share the project that is causing these crashes? We’ve got the details from the crash reporting for where it’s going wrong.
I observe the same issue on my system. If I don’t save before running the DRC , the program occasionally crashes, and all changes are lost forever. But if I save beforehand, everything works fine.
Windows 11
KiCad x64 on x64 Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (ŃĐ±ĐŸŃ€Đșа 22631), 64-бОт рДЎаĐșцоя, 64 bit, Little endian, wxMSW
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Hi James,
I cannot share the current project - not all mine.
9.01 seems to have fixed the majority of the crashes, I have had one crashes where I was having 5-10.
9.01 does seem quite sluggish, I wonder if the ‘system requirements’ for memory might need updating - It seems to guzzle all available memory quite often but I have double the ‘recommended’
Thanks
while not having hard facts (yet), I also have to say that 9.0.1 “feels” slower than 9.0.0 on Win10 and 11.
Will update this in case I can quantify this a bit better.
There are over 90 bug fixes since 9.0.1 in “Testing”.
Some might cause memory leaks.
