I have looked throughout out PCB editor documentation, and can’t find it.
I would like to set different layer defaults for the value and reference for a footprint. I thought this was in older version based on internet searches. Either I am missing where you set layer defaults for these values or it’s not there. Also wondering why changes to text formatting doesn’t apply when you change settings.
I think you can move all texts selected in some way between layers at PCB.
I have never used it. I use only my own libraries and I have references and value at layers I want.
So I move them once for each footprint - when I copy it from KiCad library into my library and modify it according to how I want it be.
Thanks, that helps but it is for individual footprints.
I actually just found it in the pcb editor under Edit tab - text and graphic properties.
Seemed to me it should have been under the board settings, but it does work. Here you can set your settings for layers and sizes for all of the components on the board
