Hello everyone,
I drew the holes in the antenna cover in the image as pads. I also drew the mounting holes on the side as pads. I do not want to cover the pads on the antenna and cover the pads on the side.
for any pad you can select which layers to use, for pads to be covered by solder mask you have to deselect the F.Mask and B.Mask options:
for footprints you also can set standard pad configurations
Thank you for answera @Tojan
