KiCad 8.0 crashes when opening PCB or SCH from KiCad Project file
What I have tried:
  • initially i was on v7, and upgraded to v8
  • clean reinstall of v8, including deletion of AppData files
  • Windows Update
  • Graphic Drivers were up to date
  • Removing Python from path before reinstalling
Do you have any recommendations? Is there any extra info needed? Thanks
Please post your full KiCad version information . . . you can copy it from Help > About KiCad > Copy Version Info
Here it is:
Application: KiCad x64 on x64
Version: 8.0.1, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Mar 15 2024 01:52:47
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
The version information looks good, and there is no issue known which generally produces a crash at loading a schematic/pcb file.
  • Yes it happened with all of them
  • I tried the one attached, but still crashing
  • Same for demo projects
  • Yes, I tried it, still crashes
So if all projects (schematic+board files) are crashing I think it depends on your computer system / windows installation.
Could you change the global Preferences setting prior to opening the schematic/pcb files:
  • common section: aliasing completely off
  • schematic/pcb editor → display section: use fallback graphics
  • schematic editor: default font == kicad font
  • Data collection: enable data collection and set (reset) a unique Sentry ID
  • after changing these settings close kicad (this saves the settings), then restart and try to open a project/schematic/board again.
Do you work from a network drive? Do you have installed kicad on a non-standard path?
If you have enabled the data collection provoke 1…2…3 crashes, then you could open a gitlab bugreport (from main project manager-_>Help–>Report bug) and provide your Sentry ID in this bugreport. If the crash was catched by the data collection engine then some information should be collected for the developers.
Okay with fallback graphics it works! Thanks a lot!
Then this should be surely be an issue of my graphics drivers. I’m not sure what could it be since there are no updates and I have not made any recent changes that could provoke this behavior. Thanks again!
The 3D viewer does not work though still.
I suggest you try viewing step files with “CAD Assistant” by Open Cascade. It is a free utility that does nothing but view step files. It will prove or disprove you computer & graphics is capable as it uses NO kicad files.
