Hello everyone.
I designed a PCB with teardrops enabled at various hole locations, and it’s working properly.
But when I copy it to pcb editor to create a file for making pcb at home, I found that the teardrop is not displayed properly.
What did I do wrong? Why isn’t it showing?
Teardrops are leading a bit of their own life in KiCad. I can’t even select them for example. So you also can’t copy them. It also looks like none of your boards have teardrops. If you want teardrops, just regenerate them with: PCB Editor / Edit / Edit Teardrops.
Also: Update to KiCad V8.0.9 if you want to stick with the V8 series.Increments in the third number are bug fix updates, and less bugs is more betterer.
