Kicad 8.0.7 Image converter does not match the model
Hello all
I created an image file and saved it as .tif
But the image conversion process is not sharp, the resulting lines
are not straight, or did I set something wrong?
The result is not the same as the designed image.
this image file
on converter not good
i config
can fix ?
I had the best results when using ridiculously high source resolutions (something like 8k pixels wide or more) and setting the threshold to 0. But yes, it is quite annoying that I have to export a vector file as a pixel file, just to convert it back to a vector.
But if you want to place it in the PCB editor not the schematic editor (or in a symbol), you can just import an SVG, that is the best solution.
It is possible to import SVG/DXF directly to the footprint editor as well. Starting from 8.0, to schematic/symbol editors too.
but not in the drawing sheet editor afaik. At least I was unable to import a SVG to a drawing sheet in KiCad 8
Are there any video tutorials or documents to read?
Here’s basically all the menus to import SVG/DXF in 8.0:
PCB editor:
Footprint editor:
Schematic editor:
Symbol editor:
i try svg inkscarp
and photoshop
and import not work ?
no text
i miss some thing ?
Can you post it here?
OK i can try on
inkscap > need change font to path
Update i try on Inkscape is ok
good job ! easy
on photoshop is ok but not sure for easy
convert to shape
set export option
and import to foot print
Ok thank you
