KiCad 8.0.5 - Reopens after closing. Also got one strange crash
I’m having one little problem with KiCad 8.0.5 and 8.0.6 which re-opens a few seconds after being closed.
This happens whether there is an open project or not. The second instance won’t re-open once closed.
KiCad version info below.
I also encountered something strange under the pcb editor before switching from 8.0.5 to 8.0.6 .
As it happened only once, I couldn’t reproduce it so far, and don’t clearly remember after what actions this happened, but I was mainly doing some grouping / ungrouping, cutting / pasting, adding vias between components located inside a grounded area (and re-filling the area). Sometime among all this, one via of another grounded area got its net name changed and grayed. Furthermore, the undo history disappeared. After closing KiCad, a crash pop-up raised saying that a breakpoint was met.
I will update if I manage to reproduce.
Application: KiCad x64 on x64
Version: 8.0.6, release build
wxWidgets 3.2.6
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
libcurl/8.8.0-DEV Schannel zlib/1.3.1
Date: Oct 14 2024 01:02:33
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 43
Compiler: Visual C++ 1939 without C++ ABI
Always post the version and OS info.
What version exactly ? can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
I added the OS & KiCad infos.
I also have this issue and I’m using 8.0.5
Application: KiCad Schematic Editor x64 on x64
Version: 8.0.5, release build
wxWidgets 3.2.5
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
Platform: Windows 11 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) UHD Graphics 730, 4.6.0 - Build 30.0.101.1002
Date: Sep 7 2024 02:39:48
wxWidgets: 3.2.5 (wchar_t,wx containers)
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 42
Do you have anonymous crash reporting enabled (it’s in the KiCad preferences under ‘Data collection’)? If so, please file a bug report and include your collection ID. You can make it confidential if you want only the lead devs to be able to see your collection ID.
Same comment - please enable crash reporting and log a bug report if you experience a crash. We should be able to look up the details from your reporting ID.
Sorry for not answering this earlier. I just enabled it, but didn’t have any crash since the last one.
However, KiCad always re-opens once after being closed.
Have you tried with 8.0.6?
Yes, same problem with 8.0.6.
Do you have some kind of built-in or add-on software to the OS that saves the running applications on shutdown to reopen them after the OS has restarted? Could it be misbehaving?
No. Only happened each time I closed with KiCad. However the problem didn’t occur the last two times I used it. Very strange. I will update if the problem comes back.
