Unlike previous 8.0.* versions that compiled well, this version compiling resulted in the following:
[ 8%] Building CXX object common/CMakeFiles/kicommon.dir/exceptions.cpp.o
[ 8%] Building CXX object common/CMakeFiles/kicommon.dir/kiid.cpp.o
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:50:15: error: ‘mt19937’ in namespace ‘boost’ does not name a type
50 | static boost::mt19937 rng;
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:51:52: error: ‘mt19937’ is not a member of ‘boost’; did you mean ‘std::mt19937’?
51 | static boost::uuids::basic_random_generator<boost::mt19937> randomGenerator;
In file included from /usr/include/c++/14.2.0/random:48,
from /usr/include/boost/uuid/detail/random_device.hpp:65,
from /usr/include/boost/uuid/detail/random_provider.hpp:9,
from /usr/include/boost/uuid/basic_random_generator.hpp:11,
from /usr/include/boost/uuid/random_generator.hpp:10,
from /usr/include/boost/uuid/uuid_generators.hpp:14,
from /tmp/SBo/kicad-8.0.5/common/kiid.cpp:28:
/usr/include/c++/14.2.0/bits/random.h:1717:37: note: ‘std::mt19937’ declared here
1717 | 0xefc60000UL, 18, 1812433253UL> mt19937;
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:51:59: error: template argument 1 is invalid
/tmp/SBo/kicad-8.0.5/common/kiid.cpp: In constructor ‘KIID::KIID()’:
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:90:37: error: ‘randomGenerator’ cannot be used as a function
90 | m_uuid = randomGenerator();
/tmp/SBo/kicad-8.0.5/common/kiid.cpp: In constructor ‘KIID::KIID(const std::string&)’:
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:152:41: error: ‘randomGenerator’ cannot be used as a function
152 | m_uuid = randomGenerator();
/tmp/SBo/kicad-8.0.5/common/kiid.cpp: In member function ‘size_t KIID::Hash() const’:
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:244:36: error: invalid cast from type ‘const boost::uuids::uuid::data_type’ to type ‘const uint32_t*’ {aka ‘const unsigned int*’}
244 | boost::hash_combine( hash, reinterpret_cast<const uint32_t*>( m_uuid.data )[i] );
/tmp/SBo/kicad-8.0.5/common/kiid.cpp: In member function ‘void KIID::ConvertTimestampToUuid()’:
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:275:41: error: ‘randomGenerator’ cannot be used as a function
275 | m_uuid = randomGenerator();
/tmp/SBo/kicad-8.0.5/common/kiid.cpp: In static member function ‘static void KIID::SeedGenerator(unsigned int)’:
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:302:5: error: ‘rng’ was not declared in this scope
302 | rng.seed( aSeed );
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:303:67: error: ‘mt19937’ is not a member of ‘boost’; did you mean ‘std::mt19937’?
303 | randomGenerator = boost::uuids::basic_random_generator<boost::mt19937>( rng );
/tmp/SBo/kicad-8.0.5/common/kiid.cpp:303:74: error: template argument 1 is invalid
make[2]: *** [common/CMakeFiles/kicommon.dir/build.make:702: common/CMakeFiles/kicommon.dir/kiid.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:3256: common/CMakeFiles/kicommon.dir/all] Error 2
make: *** [Makefile:166: all] Error 2
Is it a problem with boost version or so ?
