rdtsc
                    June 2, 2024,  7:46pm
                  1
              Hi, exactly like in Crosshair missing in v.6.99 and 7.0 - #13 by suzizecat , all crosshairs are not rendered in accelerated graphics mode, but appear fine in fallback mode.
This is on a 13th-gen Intel machine running Mabox (Manjaro) Linux with an RTX 3060 video card:
01:00.0 VGA compatible controller: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1) (prog-if 00 [VGA controller])
Other apps work normally including graphics-intensive ones like Blender, FreeCAD, ComfyUI, hashcat, etc.  Any ideas?
              Try using Nvidia’s proprietary driver instead of Nouveau.
                rdtsc
                    June 2, 2024, 11:38pm
                  3
              Hmm interesting, having difficulty disabling/removing nouveau.  This seems to be a moving target, motphing over the years.
Found xf86-video-nouveau installed; removed.
Saw many posts re: “disable noveau” such as https://linuxconfig.org/how-to-disable-blacklist-nouveau-nvidia-driver-on-ubuntu-20-04-focal-fossa-linux  but the arch / manjaro equivalent did nothing.
Checked /etc/mkinitcpio.conf (and mkinitcpio.d) and no references to nouveau.
Rebuilt grub and mkinitcpio many times during.
See in NVIDIA - ArchWiki  section 1.5 to disable kms in boot to prevent nouveau - nope.
That also says that installing nvidia-utils will disable nouveau, and that was already installed.
Tried sudo rmmod nouveau and it is not found. lsmod does not list nouveau.
Still getting in sudo lspci -v | less followed by /VGA:
Is nouveau even still there / loaded?  Checking KiCAD again, nope, still no crosshairs on accelerated graphics only.  What else can I try?
              If you use the official installer from Nvidia it will guide you through the steps including blacklisting nouveau from both the initcpio and the filesystem.
The download page is here: Official Drivers | NVIDIA  Enter your card model and other info and it will take you to the installer.
              Running KiCad 8.0.2 under Manjaro with KDE/x11, I also experience the missing crosshair cursor in accelerated graphic mode.
Version: 8.0.2, release build
	wxWidgets 3.2.5
	FreeType 2.13.2
	HarfBuzz 8.4.0
	FontConfig 2.15.0
	libcurl/8.8.0 OpenSSL/3.3.0 zlib/1.3.1 brotli/1.1.0 zstd/1.5.6 libidn2/2.3.7 libpsl/0.21.5 libssh2/1.11.0 nghttp2/1.62.1 nghttp3/1.3.0
Platform: Manjaro Linux, 64 bit, Little endian, wxGTK, X11, KDE, wayland
	Date: Apr 28 2024 16:02:51
	wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
	Boost: 1.83.0
	OCC: 7.7.2
	Curl: 8.7.1
	ngspice: 42
	Compiler: GCC 13.2.1 with C++ ABI 1018
	KICAD_USE_EGL=ON
                system
                    September 1, 2024, 10:05am
                  6
