Hi
I suspect this is a bug, but Gitlab will not play ball at the moment.
I gave created a footprint, for a 5 pin Molex connector, not using the one in the standard library because this one has little “spurs” that mount it to the board, so needs edge cuts detail.
As is normal for me I have created the pads with an asymmetric extension on the B side to make them easier to solder.
That was something of a drama initially, but I’ve now found my way around the pad editor, and remembered the trick of overlaying two pads with the same pad numbers, with a SMD pad on the b side. I’m now very happy with my new footprint.
However the 3D view of the footprint is odd. The a and b sides are revered, with the the extended pads on the top surface, along with the front side silk screen, and the 3d Model, and the standard pads on the reverse side.
The non 3D view of the footprint is normal, and gerbers are as I would expect with the extended pads correctly on the b side.
I suspect a bug in the 3D viewer. In most cases the confusion of the swap of the a and b side copper details would not be very noticeable as for most footprints the a and b side copper is the same.
I have built a simple test board with just the footprint, and an edge cuts outline that shows the issue pretty clearly. I can post it here, though I’m not sure the 3D model of the connector will transfer with the board archive.
File:
K8_testing-2024-04-15_140109.zip (6.1 KB)
Harry
ps I checked the downloaded file, and it contains all the info, including the 3D model
