In the component footprint editor and in the PCB editor, there is a display problem in the “Edit → Edit Text and Graphic Properties” window. The “Layer” line is very narrowed.
P.S. Changing the window size does not solve the problem.
Version: 8.0.0-rc2, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Platform: Windows 10 (сборка 19041), 64-бит редакция, 64 bit, Little endian, wxMSW
Date: Jan 21 2024 19:32:51
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
jmk
February 2, 2024, 5:58am
2
My box is correct; however the “Layer” and “Font” wording is slightly offset.
@marko1977 I noticed your version is dated Jan. 21 Maybe try a newer version?
Version: 8.0.0~rc2-1e5b68cb87~176~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.16
Platform: Linux Mint 21.2, 64 bit, Little endian, wxGTK, X11, cinnamon, x11
Date: Jan 31 2024 15:06:42
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.81.0
ngspice: 40
Compiler: GCC 11.4.0 with C++ ABI 1016
Is the dialog fully maximized /full size ??? I get the same if the dialog is not max size.
Maybe…
However, I noticed that your operating system (Linux) is different from mine (Windows). Perhaps the problem is observed in the Windows version.
@GE , No, changing the window size does not solve the problem.
jmk
February 2, 2024, 6:17am
6
True; but this is still the “Nightlies” with daily updates to the program, so you need to try the latest version first, because that problem may have been corrected in the last week.
@jmk , Thank you for the clarification. I’ll check this, but only later, since it’s not possible right now.
hmk
February 2, 2024, 10:41am
8
On my system yesterdays nightly does not have the narrowed problem, but the test is somewhat offset to the right compared to the ones below.
Version: 8.0.0~rc2, release build
wxWidgets 3.2.4
FreeType 2.13.1
HarfBuzz 8.2.1
FontConfig 2.14.2
libcurl/8.2.1 OpenSSL/3.1.1 zlib/1.2.13 brotli/1.1.0 libidn2/2.3.4 libpsl/0.21.2 (+libidn2/2.3.4) libssh/0.10.6/openssl/zlib nghttp2/1.55.1 OpenLDAP/2.6.6
Platform: Fedora Linux 39 (KDE Plasma), 64 bit, Little endian, wxGTK, X11, KDE, wayland
Date: Feb 1 2024 18:28:35
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.81.0
OCC: 7.6.3
Curl: 8.2.1
ngspice: 42
Compiler: GCC 13.2.1 with C++ ABI 1018
marekr
February 2, 2024, 12:27pm
9
It’s a real issue because that layer box is more complicated than it looks
This is true. This has been fixed in the newer version.
marekr
February 3, 2024, 2:06pm
11
Meh, I’ve tried to fix it but it’s still randomly happening grrr
system
Closed
May 3, 2024, 2:07pm
12
