KiCad 7 upgrade on Ubuntu
When I do “sudo apt upgrade” on Ubuntu. I get a message that kicad is held back. It seems to be confused by several upgrade possibilities. What should do to always upgrade to the latest KiCad 7 release?
The following packages have been kept back:
kicad
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
$ apt list --upgradable -a
Listing… Done
kicad/focal 7.0.11~ubuntu20.04.1 amd64 [upgradable from: 7.0.10~ubuntu20.04.1]
kicad/now 7.0.10~ubuntu20.04.1 amd64 [installed,upgradable to: 7.0.11~ubuntu20.04.1]
kicad/focal 6.0.11-0-202302012048+2627ca5db0~126~ubuntu20.04.1 amd64
kicad/focal 5.1.5+dfsg1-2build2 amd64
This came up on a server forum a while back. It seems Ubuntu has a ‘staged’ introduction. You have to opt in to an early adopters setting somewhere to get ‘the latest’. Otherwise it is held back for a couple days to see if there is any problem. This really sux on a server where the user interface kinda by passes that setting and you get the update right away. Dangerous on a server.
Do you have 5 and 6 also installed?
The held back problem is sometimes also due to dependency issues.
Have you tried
sudo apt-get update
sudo apt-get dist-upgrade
This will make sure all your packages on the OS are up to date.
What version of Ubuntu are you running?
Otherwise leave it a few days and sometimes the problem just fixes itself due to Ubuntu phased updates
Thank for the comments,
I ran “sudo apt dist-upgrade” and that seems to have fixed the problem. I have kicad 1.0.11 now.
The Ubuntu hold back bothered me at first but now I am ok with it. They claim to be doing a staged rollout so that a few users do more testing before everybody gets it. On a server, I can see how that might get complicated.
