KiCad 7.0.7 crashes when loading database library (was working in 7.0.6)
Hello fellow Kicad users,
Just updated from 7.0.6 and I tried opening a known working project that uses my database library. Kicad 7.0.7 just crashes silently whenever I use the “Add component” command and the libraries are loaded for the first time. The problem must be in my database library because the panel successfully loads when I deactivate that library.
Also, when opening a specific project, Kicad complains that it is already opened, even after restarting the PC. This problems is unrelated, but I will also appreciate some help figuring out what is happening.
It would be cool if someone could brief me on how to gather a crash report or similar info, so that I can open an issue in gitlab. As commented, right now it just fails silently without anything to report.
Kind regards,
Enrique
Version: 7.0.7-7.0.7~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 6.0.0
FontConfig 2.13.1
libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.16
Platform: Pop!_OS 22.04 LTS, 64 bit, Little endian, wxGTK, pop, x11
Date: Aug 13 2023 23:14:49
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.88.1
ngspice: 38
Compiler: GCC 11.4.0 with C++ ABI 1016
KICAD_SPICE=ON
Seeing that you are on ubuntu probably the most useful thing you can do is install the debug symbols package for kicad (if I remember correctly it is called kicad-dbg), run kicad under debugger gdb, trigger the crash, get the backtrace and attach it to a bug report filed on gitlab.
If you are unfamiliar with how to use gdb gdb tutorial has a good example, you will only need run and backtrace commands.
Next best thing if you can’t provide a backtrace is to just file a bug report and describe exact steps you take for a crash as well as exact configuration for your database library. One of the devs will then guide you on how to obtain more information if needed.
Probably due to the lock file left behind on abnormal exit. Search for other threads about this.
If you can open a bug report including your database library, I can investigate. Mark it a confidential issue if you do not want your library to be public. Gathering a crash report (backtrace) can be done as qu1ck said, but you don’t have to do it before opening a bug report.
Thanks to everyone for the nice responses.
I was able to run dbg and get the backtrace info. I opened an issue in gitlab:
Thank you for contributing to make KiCad better for everyone :slight_smile:
