KiCad 7.0.1 area fill broken
I have a situation where an area fill works fine in 7.0.0 but is broken in 7.0.1.
This is the correct version generated with 7.0.0:
This is the broken version generated with 7.0.1:
Are you able to post your project for analyze ?
This OK?
(removed file)
This seems to work better…
(removed file)
The kicad project file *.kicad_pro is missing.
If you use the kicad manager → File–>Archive project you will get a complete zipped project with all necessary files.
I can do that but I may have to use wetransfer or something as this creates a file of 31MB. Also, I do not wish to make the entire project public on the forum. Is it possible to send to the developers via PM?
Open an issue on GitLab, mark it as confidential, and attach the file there. The devs use GitLab rather than this forum for handling bug reports.
(use the Help → Report Bug menu entry as a shortcut)
Should be in GitLab if I did it correctly :slightly_smiling_face:
If it is marked “confidential” it won’t show in the list. You will get confirmation from developers I assume.
