When I open KiCad 6 for the first time, I’m prompted with a window (“Configure KiCad Settings Path”) offering either the ability to import settings from a previous version or start with default settings.
The choice “Import settings from a previous version at:” shows the correct location of the previous settings (for instance /home/user/.config/kicad).
However, selecting this choice seems to do nothing.
For example, the paths to symbol and footprints libraries are not imported at all. The paths shown in “Configure Paths” are the default ones (KICAD6_FOOTPRINT_DIR, KICAD6_SYMBOL_DIR…)
Same for Global Symbol Library Table (I have to specify “Copy custom global symbol library table” and manually look for the correct “sym-lib-table” file)
Idem for Global Footprint Library Table (with “fp-lib-table”)
In these two windows, the paths KICAD_SYMBOL_DIR and KISYSMOD are empty.
The expected behaviour would be, in my opinion, to get those paths correctly retrieved and integrated into KiCad 6 settings. Otherwise, I don’t see the real purpose of this wizard…
Also, just as a side note: if a lib cannot be found in “Symbol Libraries” window, when closing it by clicking “Ok”, you get an error message stipulating “Symbol library failed to load. Library not found”, while closing the “Footprint Libraries” window doesn’t care if the libs are accessible or not.
Thank you
David
Application: KiCad
Version: 6.0.0-d3dd2cf0fa~116~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.11.0-44-generic x86_64, 64 bit, Little endian, wxGTK, xubuntu, x11
Date: Dec 23 2021 14:23:02
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.68.0
ngspice: 31
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_USE_OCC=ON
KICAD_SPICE=ON
