It seems that I have a problem while building the ground plane.
See image below.
I can’t find why…
See image below.
I can’t find why…
Just to make sure we are on the same page. You downloaded this project and opened it ‘as is’?
When you say ‘build’ does this mean you have tried to refill the ground plane by hitting “b”?
Hello Hermit,
Thanks for your fast reply.
Yes it’s like you say.
But i have found the problème.
I use the round track plugin all in last version at this time.
This pluging have made multiple mudification on the large track at right in the picture.
I have supress it and remade it, all is okey.
I have already see this problème with this module, he is to modify already modified track multple time and made lots of unwhanted double on the same trace.
Nevertheless there is a zone-fill problem caused by tracks consisting of “too many track-segments”.
I have created a cutdown-version of the board and would create a gitlab-issue if no one disagrees.
I think it’s a good idea
