My laptop run out of battery, and when I turned it on again my kicad file was broken. It asked if I wanted to recover but it failed.
This is the _bak file:
hamodule.sch (296.9 KB)
Is there a way to check what is wrong?
The PCBnew file seems to be OK:
hamodule.kicad_pcb (665.6 KB)
The entire project:
Thanks!!
eelik
2
For some reason the file ending is .sch while it’s actually a file made with KiCad version 5.99 (pre-6):
(kicad_sch (version 20211123) (generator eeschema)
The file ending should be .kicad_sch.
EDIT: I mean the “backup file” which you attached directly.
Thanks eelik!! Now I am really lost
Do you know where I can learn about the file names? this is a project that was originally created with Kicad 5
Thanks!
paulvdh
4
system
Closed
5
