Using a downloaded symbol and footprint for a feedtru capacitor Murata NFM21.
The air-wires are connected to the pads.
Routing a trace from a pad is not possible, the error message “cannot start routing from a text item” appears.
Thanks for your thoughts.
This is the footprint file .kicad_mod
(module "NFM21PC105B1C3D" (layer F.Cu)
  (descr "NFM21PC1")
  (tags "Filter")
  (attr smd)
  (fp_text reference FL** (at 0.000 -0) (layer F.SilkS)
    (effects (font (size 1.27 1.27) (thickness 0.254)))
  (fp_text user %R (at 0.000 -0) (layer F.Fab)
  (fp_text value "NFM21PC105B1C3D" (at 0.000 -0) (layer F.SilkS) hide
  (fp_line (start -1 -0.625) (end 1 -0.625) (layer F.Fab) (width 0.2))
  (fp_line (start 1 -0.625) (end 1 0.625) (layer F.Fab) (width 0.2))
  (fp_line (start 1 0.625) (end -1 0.625) (layer F.Fab) (width 0.2))
  (fp_line (start -1 0.625) (end -1 -0.625) (layer F.Fab) (width 0.2))
  (fp_line (start -1.9 -1.55) (end 1.9 -1.55) (layer F.CrtYd) (width 0.1))
  (fp_line (start 1.9 -1.55) (end 1.9 1.55) (layer F.CrtYd) (width 0.1))
  (fp_line (start 1.9 1.55) (end -1.9 1.55) (layer F.CrtYd) (width 0.1))
  (fp_line (start -1.9 1.55) (end -1.9 -1.55) (layer F.CrtYd) (width 0.1))
  (fp_line (start -1.5 -0) (end -1.5 -0) (layer F.SilkS) (width 0.1))
  (fp_line (start -1.6 -0) (end -1.6 -0) (layer F.SilkS) (width 0.1))
  (fp_arc (start -1.55 -0) (end -1.500 -0) (angle -180) (layer F.SilkS) (width 0.1))
  (fp_arc (start -1.55 -0) (end -1.600 -0) (angle -180) (layer F.SilkS) (width 0.1))
  (pad 1 smd rect (at -1.000 -0 0) (size 0.600 0.800) (layers F.Cu F.Paste F.Mask))
  (pad 3 smd rect (at 1.000 -0 0) (size 0.600 0.800) (layers F.Cu F.Paste F.Mask))
  (pad A2 smd rect (at 0.000 0.625 0) (size 0.600 0.650) (layers F.Cu F.Paste F.Mask))
  (pad B2 smd rect (at 0.000 -0.625 0) (size 0.600 0.650) (layers F.Cu F.Paste F.Mask))
  (model NFM21PC105B1C3D.stp
    (at (xyz 0 0 0))
    (scale (xyz 1 1 1))
    (rotate (xyz 0 0 0))
