KICAD 5 : moving a track moves only a piece of the track :(
Hello friends !
I have this issue : i trace a track and then i’d like to move (M) it in order to route it well
But only a piece of the track is moving not all of it :frowning:
Do you have an idea.
I did NOT have this problem on 4.0.7 version
Thank you all …
You have to learn to use the interactive push’n’shove routing with the “modern/default” toolset. ‘D’ is the shortcut for dragging a segment so that the connections and nice looking n*45 degree angles are kept.
Thank you eelik !!
On 4.0.7 version, i always used M to do so.
I never used D
So, thank you so much !!!
