As Kicad 4.0.7 has an issue in Linux Mint 19, I decided to move onto Kicad 5 through the ppa.
Then, when I was asked about to use hardware acceleration I said “Yes”, but a window poped out “OpenGL 2.1 or higher is required!”. Same happens when in PCB layout I press “F11”.
When I ask my Linux box about the OpenGL version I get this:
You might find something helpful when you use the forum’s search feature and search for that message “OpenGL 2.1 or higher is required”, it gives many hits because other people have the same problem.
Through Synaptic I installed everything that has 390 in it: libnvidia(asterisc)390(asterisc). It seems to be the latest release for nvidia’s drivers, but LM19 installed by the fault the 340 release. I have also the propietary driver enabled. I installed the bumblebee package as well, but I don’t know whether it’s needed.
PD: I cannot use the asterisc symbol, but I guess you’ve got the idea.
