I have been using Kicad for years but i recently installed Kicad 5.99
I noticed i am unable to see connector pads unless i select them? is this a bug or am am missing something here?
thank you in advance
Check the apperance panel Objects tab, likely pads are turned off. This is a bug. Was this the first time you ran 5.99? If possible, could you share the original 5.1 project in a bug report?
Thank you, I did not notice the tabs on the top. It was turned off.
First time i used this version yes.
