Hi everyone,
I encounter a strange behaviour I suspect it might be a bug or I am doing something very wrong. I am trying to build a PCB by python scripting.
I place some connectors, an outline and start drawing zones (copper pours). I have a zone that touches the outline and one connector and I observe the following:
- If the zone touches both the outline and the footprint, but I don’t call “ZONE_FILLER Fill”, but instead save the board, open it with the GUI and press ‘b’, everything works.
- If the zone touches both the outline and the footprint, but I call “ZONE_FILLER Fill” in my code, I get a segmentation fault.
- If the zone touches either the outline or the footprint, but I call “ZONE_FILLER Fill” in my code, I get a segmentation fault.
- If the zone touches neither the outline nor the footprint, andI call “ZONE_FILLER Fill” in my code, everything works.
The thing that is bugging me the most is that filling the zones with the GUI works, and by code it crashes. I uploaded a python script that reproduces the behaviour by changing the flags in lines 107 and 108 here:
I am running nightly build with the following version: (though I tried with the latest nightly build and I got again segmentation fault)
Application: KiCad (64-bit)
Version: (5.99.0-11336-g5116fa6d12), release build
wxWidgets 3.1.5
libcurl/7.74.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19042), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jul 6 2021 09:00:18
wxWidgets: 3.1.5 (wchar_t,STL containers)
Boost: 1.75.0
OCC: 7.5.0
Curl: 7.74.0-DEV
ngspice: 34
Compiler: Visual C++ 1928 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I hope I explained my problem and looking forward to hearing from you guys!
Thanks!
