After the upgrade the version of kiCad, adding filled zone is not simple as before. As you can see the attached file, the white thick line is followed by the mouse cursor. It did not happen before.
I would like to know how to reduce the thickness of the line. It is too thick to point out …
5.1.6 came out last May. Anyone using 5.1.x should backup their projects and update to 5.1.7, which seems to be one of the smoother 5.1.y releases and 88 issues closed
