HI, Running on High Sierra , 5.1.6 eschema was running fine. ( I have a whole project done ) Then suddenly eschema crashes ( spinning wheel ) , I reinstalled 5.1.6 , but still even if I create a new blank project , Eeschema open up a blank sheet with a title outline and crashes ( I’m running from the project manager )
pcbnew is running fine
haven’t a clue what to do next
PS: I reinstalled the applications and tried right click and " open in a new " tab " and tried schema directly , it started displayed a blank title and crashes. PCBNew runs fine
The KiCad preferences are in ~/Library/Preferences/kicad on macOS. If you are ever in this situation again, it is easy to simply rename the preference file to something else like eeschema_old and then relaunch the application. A default preference file will be regenerated. Comparing the two files might give a clue as to what went wrong.
