Do yo have it ?
Here is my version :
Do yo have it ?
It might be that you have one of the early version 5 builds. These had some compilation flags set that should not be set for release builds.
When did you download the installer? (There is no difference in any other thing than the date. The version number sadly did not change in any way.)
I would suggest you download the current installer from the download page and re install kicad. If that does not fix the problem then something else is the case.
Hello Rene !
I downloaded on July 24th 2018.
I will test your solution (do I have to download a nightly version ?)
I’ll be back.
Thanks.
No the normal release. (The installer should now be fixed in this regard.)
Oh i understand now !!!
I re download the same exe.
Thanks.
I have noticed that the exe downloaded on july had this size : 1 037 686 Ko
the one i downloaded right now has this size : 1 038 825Ko
Thank you René
