RC2 has rolled out!
https://launchpad.net/kicad/+announcement/13711
windows build
http://downloads.kicad.org/windows/stable/kicad-product-4.0.0_rc2-x86_64.exe
http://downloads.kicad.org/windows/stable/kicad-product-4.0.0_rc2-i686.exe
RC2 has rolled out!
windows build
probably the build, at the moment, is not still tested
Thanks dev team.
I installed rc2 on my Ubuntu15.10 from ppa:js-reynaud/kicad-4.
Then I noticed 2 packaging issues.
version info is still “rc1”
I installed rc2, apt list kicad shows like this.
kicad/wily,now 4.0.0-0rc2.201511091025+6189~32~ubuntu15.10.1 amd64 [installed]
But, Help->“Copy Version Information” shows “Version: 4.0.0-rc1-stable release build”
docs are old.
I also installed kicad-doc-en, apt list shows this.
kicad-doc-en/wily,now 4.0.0-0rc2.201511091025+6189~32~ubuntu15.10.1 all [installed]
All the pdf files are installed under the /usr/share/doc/kicad/help/en/,
and I could access them by Help menu.
But, all pdf files are old one.
And this is not a problem, just FYI for the user, demos/ directory is moved to /usr/share/doc/kicad/.
I thought with rc1, demos/ was located under the /usr/share/kicad/.
Which of the daily builds (from http://downloads.kicad.org/windows/ ) corresponds to this release candidate?
Dale
See under the stable directory.
You can find rc2.
i got this crash error on windows 8 64 bit just trying to open pcbnew
the installer is:
and I get same error with the 32bit version on 64bit windows
Did you get VC++ runtime library error on windows8 ?
Can you open other programs ?
Eeschema, gerbview, footprint editor and so on ?
Does this problem affect on pcbnew only ?
pcbnew and footprint editor will crash
it seems related to _pcbnew.kiface
here the error I got:
Problem signature:
Problem Event Name: APPCRASH
Application Name: kicad.exe
Application Version: 0.0.0.0
Application Timestamp: 00000000
Fault Module Name: _pcbnew.kiface
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: 40000015
Exception Offset: 00000000007696b2
OS Version: 6.3.9600.2.0.0.256.103
Locale ID: 1040
Additional Information 1: 4359
Additional Information 2: 4359de68b94383a431f7d72db5ff2df5
Additional Information 3: eb47
Additional Information 4: eb47d0f87c5c33c8aa46cc9e41e69717
RC2 is crashing,
dev 6305 is not crashing
I am running Windows 7 and the launcher doesn’t start. Luckily I can work by starting the Pcbnew application in the KICAD folder.
btw. tried to install RC1 after trying out RC2 and I still have the same problem with the launcher. Hopefully this will be resolved very soon.
I can use RC2 on Windows 7 without any crash.
But 4.0.0-rc2 (x86_64) on Windows 7, wxWidget Debug Alert dialog is displayed.
Application: kicad
Version: 4.0.0-rc2-stable debug build
wxWidgets: Version 3.0.2 (debug,wchar_t,compiler with C++ ABI 1009,GCC 5.2.0,wx containers,compatible with 2.8)
Boost version: 1.57.0
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
USE_FP_LIB_TABLE=HARD_CODED_ON
BUILD_GITHUB_PLUGIN=ON
How to reproduce.
This error dialog is displayed only one time after starting kicad.
I clearly made debug builds there, they will have some asserts triggered. New builds have been triggered and the ones already there should be replaced within a few hours. Please redownload when the timestamp on the server is not 08-Nov-2015 14:58 anymore.
I downloaded kicad-product-4.0.0_rc2-x86_64.exe 10-Nov-2015 01:37 and re-install on Win7.
“wxWidget Debug Alert dialog” is not displayed any more.
Thanks.
I attached version info.
Application: kicad
Version: 4.0.0-rc2-stable release build
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
Regards.
Yep, should be “fixed” now. It was just because it was a debug build.
it’s fine now
thanx
