KiBoM - Python BOM Generation tool
Hi @SchrodingersGat
I found a little bug when the script is writing html output in case of utf-8 chars (in my case it was 125°C)
I had to substitute
        html.write('\t<meta charset="ISO-8859-1">\n') #UTF-8 encoding for unicode support
to
       html.write('\t<meta charset="UTF-8">\n') #UTF-8 encoding for unicode support
probably it is just an oversight, considering your utf-8 comment :smiley:
thanks a lot for the new implementation of the grouping fields
Maurice
Thanks for the heads-up @maui, fixed :slight_smile:
Hi!
I will append my issue here since I believe it is pertinent to the thread.
I am trying to use the KiBoM tool with the PCB Configuration feature. But I can’t make it work.
I’ve added the fit_field to the schematic and filled with the required information.
The i’ve updated the BOM.ini file with the following information.
> ; Field name used to determine if a particular part is to be fitted
**fit_field = ‘**C00001’
I need to remove from the BOM file the items that are marked as “-C00001”
The only clue that I’ve is that the tool is issuing a warning saying “Field conflict: (J8 J17 J18) [fit_field] : ‘-C00001’ <- '”+Debug"’"
And looks like it is being generated because two different instances of the same part have different “fit_field” information
Anyone has used this feature before?
Thanks in advance
Hi @mcarra there’s a slight misunderstanding in your usage of the fit_field parameter.
The fit_field must specify which field the script looks in to determine if a particular part is included in the BOM. In your example above, you have defined this as C0000:
Which means the script looks for a field called C00001 (which does not exist).
If you change the line to:
fit_field = 'fit_field' then it should work with your current field naming. Or you can change this to whatever you want.
The key is that you do not specify the contents of this field in the .ini. file
Thanks
Hi!
I’ve corrected my bom.ini file with the following statement:
fit_field = ‘Config’
then i’ve updated the Config field with the sentence “-C00001”
Saved all and run the BOM tool with:
python “/home/cmartin/Desktop/KiBoM-master/KiBOM_CLI.py” “%I” “%O” “-r C00001”
And the part is still there:
Any clue?
Thanks in advance.
Martín
Sorry for the delay.
In your command line argument, remove the quotes around “-r C00001”
i.e.
python "/home/cmartin/Desktop/KiBoM-master/KiBOM_CLI.py" "%I" "%O" -r C00001
Excelent! It worked as expected!
I have another question regarding the tool: Can I set the fields that I want to show in the list?
As I can see from the documentation the tool automatically appends the field if it appears in one of the components.
I only want to see reference, value and ManufacturerPN
Any Idea on how to do this?
Thanks in advance!
Martín
Hi
I keep getting an error message when using KiBoM. Have added KiBOM_CLI.py and pressed Generate.
Found one similar error, that suggested to resave the .sch file to ANSI. But this had no effect.
Command error. Return code 1
Error messages:
Traceback (most recent call last):
File “C:/Program Files/KiCad/bin/KiBoM/KiBOM_CLI.py”, line 160, in
output_file = fname + “_” + net.getVersion() + “.” + fext
UnicodeDecodeError: ‘ascii’ codec can’t decode byte 0xf8 in position 65: ordinal not in range(128)
Hi @Martin123 I’ve fixed a few similar errors recently - it would appear in this case that the schematic version text contains some non ASCII characters (or the schematic file name itself).
Can you post the contents of your schematic filename and version / revision string so I can run some tests here and fix the issue?
Thanks for the quick reply.
I just sent you the entire project in PM
Martin
Thank you for this plugin which is very helpfull.
I added the fiel Config and the value +test in one of my componant and when I do
python “C:\Users\myUserName\Downloads\KiBoM-master/KiBOM_CLI.py” “%I” “%O” -r test
or
it appears or not in the BOM file.
However, I tried -test and either I do
or
I never have the component in the BOM file.
Did I do something wrong ? Is it a bug ?
Also is it possible to have several variants by writing +test -prod for a same component ? I tried it but it did not work.
I’m not sure if this is a good place for this question.
I just started to use this tool and the first project I tried barfed. Apparently it didn’t like the part because it’s an alias. Here’s the section in the library that shows this part:
QUAD_OP-AMP
DEF QUAD_OP-AMP U 0 20 Y Y 4 F N
F0 “U” 0 200 50 H V L CNN
F1 “QUAD_OP-AMP” 0 -200 50 H V L CNN
F2 “” -50 100 50 H V C CNN
F3 “” 50 200 50 H V C CNN
ALIAS LM324 TLC274 TL074 LM324N LM324AN MCP6004
$FPLIST
SOIC*
DIP*
TSSOP*
SSOP*
MSOP*
$ENDFPLIST
DRAW
P 4 0 1 10 -200 200 200 0 -200 -200 -200 200 f
X V+ 4 -100 150 0 D 0 50 0 1 W
X V- 11 -100 -150 0 U 0 50 0 1 W
X ~ 1 300 0 100 L 50 50 1 1 O
X - 2 -300 100 100 R 50 50 1 1 I
X + 3 -300 -100 100 R 50 50 1 1 I
X + 5 -300 -100 100 R 50 50 2 1 I
X - 6 -300 100 100 R 50 50 2 1 I
X ~ 7 300 0 100 L 50 50 2 1 O
X ~ 8 300 0 100 L 50 50 3 1 O
X - 9 -300 100 100 R 50 50 3 1 I
X + 10 -300 -100 100 R 50 50 3 1 I
X + 12 -300 -100 100 R 50 50 4 1 I
X - 13 -300 100 100 R 50 50 4 1 I
X ~ 14 300 0 100 L 50 50 4 1 O
ENDDRAW
ENDDEF
And here’s the message:
python “C:/SVN/KiCAD/KiBoM-master/KiBOM_CLI.py” -v “C:/SVN/KiCAD/Projects/TCU-Steering-Copy/TCU-Steering.xml” “C:/SVN/KiCAD/Projects/TCU-Steering-Copy/TCU-Steering”
Input: C:\SVN\KiCAD\Projects\TCU-Steering-Copy\TCU-Steering.xml
Config: C:\SVN\KiCAD\Projects\TCU-Steering-Copy\bom.ini
missing libpart for ref: U36 TL074 TCU-Steering-cache
Excluding ‘MK1’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK10’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK11’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK12’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK2’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK3’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK4’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK5’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK6’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK7’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK8’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
Excluding ‘MK9’: Field ‘Part’ (Mounting_Hole_PAD) matched ‘mount.*hole’
File “C:/SVN/KiCAD/KiBoM-master/KiBOM_CLI.py”, line 124, in
groups = net.groupComponents(components)
File “C:\SVN\KiCAD\KiBoM-master\bomlib\netlist_reader.py”, line 426, in groupComponents
g.updateFields(self.prefs.useAlt, self.prefs.altWrap)
File “C:\SVN\KiCAD\KiBoM-master\bomlib\component.py”, line 471, in updateFields
self.fields[ColumnList.COL_REFERENCE] = self.getAltRefs(wrapN)
File “C:\SVN\KiCAD\KiBoM-master\bomlib\component.py”, line 431, in getAltRefs
return S.flush(’ ', N=wrapN)
File “C:\SVN\KiCAD\KiBoM-master\bomlib\component.py”, line 347, in flush
if N!=None and c%N==0 and c!=0:
ZeroDivisionError: integer division or modulo by zero
Does anyone know how I can fix this problem?
Hi @kcminer this is a new one. I’ve just made a commit which should fix this, please grab the latest version of KiBOM and see if it works for you now…
Thank you for the swift response. Unfortunately, this didn’t seem to fix the problem. However, the problem may be elsewhere. I replaced the part with a same part from the regular library and the problem went away. It generated a different entry in the library cache. Somehow the library cache may have been stuffed with wrong information.
While playing with the bom.ini file, I noticed that if I set ‘use_alt’ to 1 it generates a divide by 0 error. That’s ok though since I just wanted to see how this behaved and I can live with this set to 0.
This is a great addition to Kicad’s built-in scripts. I wish it’s incorporated into the released version.
Thanks SchrodingersGat! After years managing with kifield, we’re now expanding our BOM repertoire to make ordering with a quantities column easier. All the built-in BOM plugins were disappointing, but KiBoM is filling the gap.
We were able to work around the focus on Part/Lib/Value fields by simply removing/adding them to/from the relevant parts of the ini file.
The only thing I wasn’t able to work around was the implicit reference to the Description field. In our case, our parts have a custom field called Description which is used to describe the part. The KiCad one is used to describe the symbol (and is meaningless as far as our BOM is concerned). Is it easy to use ours instead of the KiCad one, or have we backed ourselves into a corner by naming our field Description?
@Heath_Raftery using custom fields with the same names as the default fields will cause issues. Easiest workaround is to simply change the name of the custom fields :slight_smile:
Hi, I know this is a really old thread, but I just downloaded the KiBoM package for the first time today and there’s no KiBoM_CLI.py file in it. Couldn’t find any in the listed folders on GitHub either. Was the file renamed, or is there another file we could use?
Hi @rauty - the script has been updated and is called in a different way now - see the new instructions here
Hi, your link just brought me right back here. I’ve searched for another thread with this topic and can’t find one. Can you resend a better link please?
