Some time ago, I was using some setting which allowed to use the same width as the trace
I’m editing. Example: rerouting a segment. delete the segment, redo it with a different route.The
PCB software was keeping the same width as the currently remaining segments.
Now I’m working on another layout, but I can’t find how to enable this feature. Any hint?
You can use net classes to set the width of different types of tracks - e.g. You might set a wider ‘power’ class and allocate a number of nets to this class. When you route any net in the 'power ’ class it will automatically use the width allocated.
Hello! Thanks for your replies.
Yes, the picture seems to do what I want, but how do I set it?
I have tried to right click one track, look in the track width menu, etc,
but I don’t see any checkbox or whatever that seems to do this.
If you could give some explanation, it would be great.
Thanks!
