Jobset not creating ODB++
I’m using the jobset feature for the 1st time. I have not problem generating BOM’s, Gerbers etc.
When it completes it doesn’t generate the ODB++Files.
When I look at the log file, it says:
Insufficient permissions to save file ‘C:\Users\nasad\AppData\Local\Temp\2eb313a2-9177-4d5f-9119-8f71cdf2690b\ProjectOutputs\Single\ODB\EPC90133_B5253_Rev2_0’.
It does work thru the PCB:
File - Fabrication Outputs - ODB++ Output File
Any help would be appreciated.
Thanks
Are you by any chance running KiCad in administrator mode? Or have run it in admin mode in the past and now running it as a regular user?
EDIT: I’m not sure why that would vary between jobset and PCB editor, just a common cause of permissions issues.
scone,
I am the administrator of the machine. Seems like if I’m administrator I should have all the permissions that I need. Any idea how to fix this?
Thank you,
NASA
I did try to right click in the KiCad project file & choose, run as administrator. Same problem.
Thanks
If I try to run the jobset file with no compression, it works
FYI, I’m seeing this same thing via the kicad-cli as well.
Issue reported here: Unable to export ODB++ with compression enabled via kicad-cli (#20891) · Issues · KiCad / KiCad Source Code / kicad · GitLab
