JLCPCB Vertical Buttons Went to Grayed Out
I returned from a break to find the plugin unusable.
The top 7 vertical buttons are grayed out.
I have conducted many hours of network testing to resolve the issue.
Everything internet works.
The plugin does download the JLCPCB database.
I’ve looked at the code but cannot find the code that decides to gray out buttons.
It would be quite helpful to troubleshoot if I knew all conditions that cause the plugin to gray out the buttons.
I’m using KiCAD 6.04.
I’m referring to the plugin Bouni / **kicad-jlcpcb-tools.
Thanks in advance for any help you may be able to provide.
Thank you
The plugin is completely independent, 3rd party, and we KiCad users here can’t help with it unless there happens to be some individual here who also uses that plugin. You should probably address your question to the plugin developers. And actually I can see you have reported this there already.
