Out of curiosity, are the bridged footprints all in the same orientation? The hot knife of the HASL only blows in one direction. I wonder if it wasn’t blowing as strongly as the other side, given one side had more solder than the other…
Regarding my open via (sorry actually I think it was a thru hole pad for a transformer). This was a 2 layer board with interconnect trace on the top side. The transformer pin was soldered on the bottom but TH plating was broken. Solder (wave soldering process) did not wick up so the pin was not connected to the topside trace. I guess it is possible that mechanical stress might have broken the thru hole plating during or after the transformer was installed. But finding this open connection drove me nuts, and it was probably difficult to solder the top side of the pcb under the transformer to fix the problem.
