Hi all,
I have a bit unusual problem with one DC barrel socket from JLC (their p/n: C720557)
The rotation (usual problem with some project manufactured by JLC) is correct, but the component is shifted like below:
I’ve previously had a shift issue with V-QFN package (shift by around 0.12mm in Y axis) and fixed it by moving the footprint anchor in the FP editor.
In this case moving the anchor changes the FP position on the PCB, so I have to re-position it again, but doesn’t change anything in the POS file and looks the same in the JLC online viewer.
Seems like to set the position correct it should be shifted by X=3.3mm and Y=1.7mm.
It’s my custom FP (CONN_DC-IN-TH_DC-005-A200, not with some random anchor position, as I was testing various part placement).
It’s based mainly on “BarrelJack_Kycon_KLDX-0202-xC_Horizontal” standard KiCAD footprint with small modification and originally setting the anchor position the same as in the FP downloaded from JLC / EasyEDA (DC-IN-TH_DC-005-A200). As mentioned above - at the moment my FP anchr may be random (I think I tried 3.3mm and 1.7mm, that didn’t work, so I tried the same by negative, ythen I think 3mm each axis, but also no shift.
See FP attachements below:
CONN_DC-IN-TH_DC-005-A200.kicad_mod (4.6 KB)
DC-IN-TH_DC-005-A200.kicad_mod (2.0 KB)
I lost the patience and moved it manually while placing the order, but seems like I will use this particular part more in a future, so the “proper” fix without a manual work each time I use it would be ideal.
I create gerbers, BOM and POS files using the JLCPCBTools plugin (from Bouni) if that helps. A few orders made since I discovered the existence of it and never had problems like that.
Also the Q-VFN package shift I mentioned above was fixed and prod files generated using the same plugin.
Do you have any suggestions?
If you have time you can create a simple PCB and upload gerbers, BOM and POS to JLC to see the placement. Then re-upload POS file to see if the position is updated.
Version info below (however I don’t think this is related to KiCAD itself):
Version: 7.0.9-7.0.9~ubuntu23.10.1, release build
wxWidgets 3.2.2
FreeType 2.13.1
HarfBuzz 8.0.1
FontConfig 2.14.2
libcurl/8.2.1 OpenSSL/3.0.10 zlib/1.2.13 brotli/1.0.9 zstd/1.5.5 libidn2/2.3.4 libpsl/0.21.2 (+libidn2/2.3.3) libssh/0.10.5/openssl/zlib nghttp2/1.55.1 librtmp/2.3 OpenLDAP/2.6.6
Platform: Ubuntu 23.10, 64 bit, Little endian, wxGTK, xubuntu, x11
Date: Nov 8 2023 19:00:56
wxWidgets: 3.2.2 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.74.0
OCC: 7.6.3
Curl: 8.2.1
ngspice: 40
Compiler: GCC 13.2.0 with C++ ABI 1018
KICAD_SPICE=ON
