It's connected but: pin-connected-to-other-pins-but-not-driven-by-any-other-pin
Sorry I just mistyped. I corrected it.
Some reading from the FAQs for you in case you bump into more ERC issues.
Unlike Piotr, some of us think ERC is useful, you just have to understand what it’s saying and when to use your own judgement.
I earned my first real money in my live by designing and making a device that contained a lot of 74xx ICs. I was a student and got for it 2.5x my father month salary. The factory device doing the same cost 4x more. What I have done was chronocomparator - you put on its table the electronic watch and you see at its display how accurate is that watch (0.1s/day resolution). I made a quartz 1MHz generator. I used thermistor to stabilize temperature (BD139 was the heater). The generator was encased in polystyrene. Chronocomparator stabilized after about 15 minutes after being switched on. I found that after 8 hours it lost accuracy. The reason was the 74xx ICs give off a lot of heat and temperature inside whole case got higher than I set in generator. I made a lot of 5mm holes in wooden case of that and raised the generator temperature.
I don’t say it is not useful.
Years ago, I took over our PCB making from someone else. This person, telling what to do in turn, did not mention the existence of the ERC in Protel, and I only used what I needed and never found this function. When I decided to move to KiCad was the first time I noticed ERC, but found that to have 0 errors I have to add many symbols to my schematic I don’t like. So as I have been without an ERC for teen years I assumed it may continue to do so. Why many - because I use many ferrite beads in power lines and because I prefer continuous GND at bottom so it happens me to use 0Rs in power lines. Adding Power Flag after each of it has no sense to me.
Understood. But if I had a dollar for every time you write about avoiding ERC I could go buy a nice computer. :wink:
If you ask for a dollar for every question about power inputs not driven by power output you could earn more, I believe. But I have to admit that not a lot more :slight_smile:
I will try to hold back myself from writing this.
I don’t know if in V6 it will be possible to block that one Error. If so may be I will start to use ERC.
What is ERC?
Not quite true… I do use it often enough to not really forget.
:upside_down_face:
