Hi iam facing some drc errors in pcbnew
Can somebody pls help me in this?
please find the snapshot of errors as an attachment.
The netclass or footprint define a minimum clearance. This clearance is too large for your footprint as its two pads are violating this.
So you have two options:
Net class clearances are set in file->board setup. If you used kicad default values then it is likely that your manufacturer is capable of producing boards with smaller settings without needing to select a more expensive option. (KiCad default is quite conservative)
