I have built KiCad on Windows 10 by following these instructions. However, I get the error “Failed to load kiface library” (image below) when I press the “Schematic layout editor” button in KiCad. If I copy the _eeschema.kiface file to the folder which contains kicad.exe, the “Schematic layout editor” button works fine and I do not get this error.
Apparently, my build does not have all executables and kiface libraries in the same directory, which kicad.exe seems to expect. What is the correct way to fix this problem?
Besides, I can only launch kicad.exe from MSYS2 shell. I get an error if I try to launch it directly from Windows.
Version details:
Application: kicad
Version: (6.0.0-rc1-dev-641-g3f6819e59-dirty), release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.33.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
