Issue with my net's retnest
I’m experiencing an issue where the ratsnest in my PCB design isn’t updating properly, and the connections from my schematic aren’t reflected in the PCB outline. I’ve double-checked my schematic wiring, but the PCB editor still doesn’t show the correct net connections. Does anyone know what might be causing this and how to resolve it?
When you update the pcb are there any errors or warnings showing in the ‘update pcb from schematic’ pop up box?
Are you opening the Schematic and Layout from the KiCad project interface ? or are you opening them separately ?
Read this:
to find how to promote yourself to be able to insert your zipped project in your post.
If you give the project it will be much easier to find source of problems than to guess what you are doing wrongly.
My impression was that I wasn’t at all sure whether you were even doing ‘Update PCB from schematic’ or you simply expect that what you have in schematic should be automatically visible in PCB. You just didn’t said it clearly if you do it or not.
You used word ‘updating’ in such way that suggest you expect it to be done without your intervention.
