Issue upgrading to KiCad 9: libocct-visualization-7.6t64 : Depends: occt-misc (= 7.6.3+dfsg1-7.1build1) but 1:7.6.3+dfsg1-8~ubuntu24.04.1 is to be installed
Hi All,
Looks like I am seeing the same old bug. I cant seem to install Kicad 9 on Ubuntu 24.04 due to a package dependencies issue. Upgrading throughout version 8 has been flawless.
So far I have uninstalled KiCad v8, and removed the ppa from sources. I do not have FreeCad installed (not sure if this would be related). Here is what I am seeing:
$ sudo apt -f install --install-recommends kicad --fix-broken
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
E: Unable to correct problems, you have held broken packages.
Try uninstalling occt-misc first
No luck unfortunately.
I tried to remove occt-misc, I then added kicad-9.0-releases ppa, updated and tried to install kicad, but I am still stuck with the same error.
Seems my response was a little too quick… I did find a solution, though I am not sure if this might break something in the future.
I uninstalled occt-misc:
sudo apt-get -y autoremove --purge occt-misc
and installed the specific version that was being called for:
sudo apt-get -y install occt-misc=7.6.3+dfsg1-7.1build1
which installed fine… then:
which installed KiCad 9!
Cant wait to see test out the new changes in KiCad 9!
Yeah, this is always an annoying issue that seems to pop up with major KiCad upgrades that nobody tells you about.
My own solution, upon seeing the error, is to simply uninstall all the ā€œocctā€ nonsense, and let apt install whatever KiCad wants when I install the new version of KiCad.
Unless I was not following the correct method of uninstalling occt-misc above…
I assumed uninstalling occt-misc using the command above and allowing apt to install kicad would mean that the correct version of occt-misc would be installed… But what I saw was that the kicad installer still would not allow me to install the correct version of occt-misc, resulting in the error above.
Uninstalling occt-misc alone did not seem to correct this. I needed to uninstall occt-misc and manually install the correct occt-misc version ā€˜7.6.3+dfsg1-7.1build1’ first, then let apt install kicad.
Same problem as @Bren , and same solution as suggested to install the specific version of occt-misc.
I just tried to install KiCad 9 with `sudo apt -f install --install-recommends kicad and it installed KiCad 7 what am I doing wrong?
I have Ubuntu 24.01
TIA
try looking what you have under
/etc/apt/sources.list.d/
i had a lot of old stuff that was messing with the installation.
cleaning it up and following this this i managed to complete the install. (Ubuntu 24.04)
Thanks, that didn’t work got this:
steve@steve-home:~/Desktop$ sudo apt -f install --install-recommends kicad --fix-broken
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following additional packages will be installed:
kicad-demos kicad-footprints kicad-libraries kicad-symbols kicad-templates libfreeimage3 libglew2.2 libhwloc-plugins libhwloc15 libimath-3-1-29t64 libjxr0t64 libngspice0
libocct-data-exchange-7.6t64 libocct-draw-7.6t64 libocct-foundation-7.6t64 libocct-modeling-algorithms-7.6t64 libocct-modeling-data-7.6t64 libocct-ocaf-7.6t64
libocct-visualization-7.6t64 libodbc2 libopenexr-3-1-30 libtbb12 libtbbbind-2-5 libtbbmalloc2 libwxbase3.2-1t64 libwxgtk-gl3.2-1t64 libwxgtk3.2-1t64 python3-wxgtk4.0 xsltproc
Suggested packages:
extra-xdg-menus kicad-doc-ca | kicad-doc-de | kicad-doc-en | kicad-doc-es | kicad-doc-fr | kicad-doc-id | kicad-doc-it | kicad-doc-ja | kicad-doc-pl | kicad-doc-ru | kicad-doc-zh
kicad-packages3d glew-utils libhwloc-contrib-plugins odbc-postgresql tdsodbc wx3.2-doc
The following NEW packages will be installed:
kicad kicad-demos kicad-footprints kicad-libraries kicad-symbols kicad-templates libfreeimage3 libglew2.2 libhwloc-plugins libhwloc15 libimath-3-1-29t64 libjxr0t64 libngspice0
0 upgraded, 30 newly installed, 0 to remove and 23 not upgraded.
Need to get 104 MB of archives.
After this operation, 655 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Any help gratefully accepted
Did you add the Ubuntu PPAs for KiCad as explained on the download page Install on Linux | KiCad EDA ? The packages are not in the official Ubuntu repos and won’t automatically upgrade an existing installation. Also remove any out of date repos from your configuration.
I followed the procedure and all is now well, many thanks for the help.
Steve W
it seems libocct-visualization-7.6t64 from ubuntu24.04.1 depends on an older version of occt-misc, which not available from 24.04 mirror, but still available in 24.10 mirror
short term workaround will be, just download the deb then install by sudo dpkg -i xxx.deb
http://launchpadlibrarian.net/722300396/occt-misc_7.6.3+dfsg1-7.1build1_all.deb
for long term, they gonna fix the dependency issue, but who knows when…
When I ran the command, sudo apt-get -y autoremove --purge occt-misc my existing KiCAD 8 was removed right along with it. Whoops!
So I went ahead and removed the ppa as well: sudo add-apt-repository --remove ppa:kicad/kicad-8.0-releases just to be sure there was no confusion in the subsequent install command. (I had both 8 and 9 ppas on my system when I tried to install 9)
Is the real issue trying to install the new version when the older one is still on the machine?
Yes. For Ubuntu the KiCad 8 and KiCad 9 PPAs are built using different versions of OCCT and they can’t coexist. If you need to run both versions in parallel, you can use Flatpak for one of them.
Same error seen here, using Linux Mint 22.1.
Thinking it might be a KiCad 8/9 conflict I tried uninstalling 8 and deleting the KiCad 8 PPA but 9 still would not install (same error). I then tried @Bren’s procedure and it seemed to work.
This should also work:
sudo apt update
sudo apt remove "*occt*"
sudo apt install kicad
Removing the older KiCad ppa’s fixed it for me. After I added the 9.0 ppa, I went and looked to see that I also had 7 & 8 ppa’s in /etc/apt/sources.list.d Removing them solved the issue.
This fixed my problem completely. Before I removed the old KiCAD v8 reference in /etc/apt/sources.list.d occt-misc was being held back. Many thanks to everyone here for helping resolve this issue!
