Your expectation is correct, a search for “PA” should not deliver “PA_RX” if “word” is checked.
Nevertheless I can’t reproduce the issue, on my 7.0.2-install the search works as expected.
If possible attach your project (maybe stripped down to only that nets+footprints) - so we can check if this depends on some project settings.
Edit:
some more research shows there really could be a hidden bug - sometimes the search doesn’t produce the desired result. But until now I have no reliable reproduction steps for the developers. On every new kicad-start (and than opening the example project) the search works correct again.
Maybe someone has more luck to build a reliable showcase?
This is the second time I seeing someone saying they are seeing a different thing.
The last one was the shortcut n to change the grid inside the Symbol Editor, which is not do anything for me.
Win10. But I think it doesn’t depend on the system. My first problem with “reproduction not possible” was that it depends on the search phrase. I had used different random strings on a existing board which worked correct - so I wrote “not reproducible for me”.
It’s because your instructions are not as clear as you think. Your opening thread sounded like a general problem - it was not obvious that the problem only shows up with specific search strings. And thats always my reason to ask for a example - it makes the reproduction so much easier.
@RaptorUK: I think you are right, most probably the “_” (underscore) is treated as space and so separates the string “PA_RX” into “PA” and “RX”.
