Hello all,
First post here…
I am getting my way around PcbNew pretty well now but right not I am experiencing something very annoying!
As the title said, it might be my computer (win10) or it might be a bug in kicad but before posting a bug report I would like to check with the community.
Here goes…
I understand how works the right panel where I can select the layers to be viewed and rendered. In this case I am making a board with only Fcu and Bcu layers.
When I press + or - the checked layers will change for the upper or lower layer even if I am not using the intermediate layers.
So far that is fine…
BUT, when I am routing a net, if I wrongly press+ instead of -, or vice-versa, the check mark will go on one of the inner layer and will stay there, the + or - command does not work anymore!
The only way to get out of this state is to hit the escape key, which will clear the tracks that I was routing. Then I can move the check mark again as usual, and retrace the net.
The system is not frozen, it’s just this command (switch layer) that seems to be buggy.
Any one with an idea?
Thanks, Luc
