Is there any way to give different color and thickness to the wires in Eeschema?
Is it possible to give the wires a different color or thickness?
Mostly I have the problem to see if GND and voltages (VCC) are connected correctly.
So it would be very helpful to make them bigger or with another color if needed.
Thanks!
This would be a great feature. For me, I would use it to indicate high current wires, for instance in a switching converter.
You will need to add this to the buglist as wishlist item.
The .sch file currently doesn’t hold these kind of information/attributes for wires:
Wire Wire Line
6425 2150 6425 1575
Connection ~ 6425 1575
