You have drawn a track that is 15 mils wide that goes between some component pads that are 20 mils apart. If you select the track and edit it to make it 20 mils wide it now is wide enough to touch both pads.
Obviously you can manually add track segments to make the track narrower between the pads.
Is there any way to make KiCad automatically make the track narrower between the pads?
While drawing a track you can use the right mouse button and click on “Select Track / Via width” to change track widht while drawing tracks.
If you look at the hotkey shortcuts there are also some track related keys I have not used yet. Did a short experiment, pressed “q” while drawing a track, and you can type in a new with to continue a track with.
I do not know what the “w” and [Ctrl + W] do.
The list was empty, so I filled in 0.3mm, 0.8mm and 2mm, and after closing the window started a new track with X. Now W and [Ctrl + W] do indeed switch between the pre-defined track widths in this list.
This list always appears to be empty on new projects. How is the new project supposed to know what track widths, and via sizes it should line up. In any case you found it. That’s what counts.
Having a list of pre-defined tracks with 30% inrements or so would at least have the W and [Ctrl+W] keys do “something”, which would make it easier to use for new users.
Also, pressing “w” a few times in a row to get to fat tracks is a pretty intuitive way of working.
I also find it (very mildly) dissapointing that “W” and [Ctrl + W] do not work when you select a track or net. All this is low hanging fruit and may already on some wish list. Just a few days ago I got an launchpad account, and there seems to be some kind of voting system there. I may take some time to go through wished features and drop some votes over there.
New Users need to read the manual; and possibly be willing to explore the software a little bit before complaining.
I’m used to the V4 nightly GUI interface with KiCad; however, it did not take me long to look and understand the new GUI selections for adding additional trace widths; users are not looking very hard…
