Is there any Switch Footprint Library?
is there any Switch Footprint Library?
in a project I need some SPDT toggle switch. I don’t see any library in KiCAD.
ok i can create a footprint but first I wanted to know whether or not is there already something by default (I don’t see it)
Heaps of switches when I use switch as a filter term.
Those are dip switches, push, and buttons and tactile … I don’t see the series with the lever
like this:
here what I have
Those you’d probably have to make from the datasheet or download from the manufacturer. Usually they have a regular pin spacing so you’d just have to get the courtyard and 3D model right.
ok then I will make it.
Switches are like connectors: many footprints but never the one you want. :slightly_frowning_face:
