Is there an easier way to refactor
This may be because I’m beginner and I don’t know how to structure schematic ahead of time. I find myself needing to refactor a schematic into several ones once they grow too complicated I find it very painful in KiCad:
  1. Select items I want to move to new schematic and cut them
  2. Go to new schematic
  3. Paste special → keep references
  4. Add hierarchical labels
  5. Connect hierarchical labels
  6. Hope you have not forgot to paste as special instead of normal paste
  7. Update PCB with relink
  8. Annotate schematic
  9. Update PCB wihout relink
  10. Save schematic
  11. Hope KiCad doesn’t crash (currently 8.0.x is unusable for me due to issue #17953 an 8.99 crash from time to time)
  12. Save PCB
It’s a long and error-prone process and if you do something wrong and KiCad crashes you need to fix it manually. Is there a better way to do it or should I file a UX bug?
Maybe it is worth changing your worksheet size. eg. If you are using A4, change to A3.
Find this at: File > Page Settings > Size.
KiCad still has no way to move a section of a schematic to another hierarchical sheet without loosing the UUID’s that connect the symbols with footprints on a (partially designed) PCB. The Paste Special combined with Re-Link footprints is the only way I know to repair these links again.
The rest of your workflow is pretty much arbitrary and you just do whatever workflow fits the job.
One thing missing in your workflow: The Re-Linking after Cut and Paste Special relies on matching RefDes between schematic symbols and PCB footprints. Therefore you should ensure that these match before you do the Cut & Paste Special thing.
