on Schematic (version 9.x.x)
is there a way to customize the FIELDS here in properties panel? By adding some required custom field?
I have LCSC field and Documentation field I want to add.
This is not currently possible and apparently deceptively difficult to implement. If it is important to your workflow, however, you can give this issue a thumbs up on Gitlab (no comments on the issue required).
Done, thank you. It’s really useful if it could be present.
