When I draft schematics, if I use hierarchical sheets, I often like to break them into functional groups. For example, if I have an analog section for a specific measurement, I’ll put that circuit inside the sheet, and the micro-controller IO in a separate sheet.
My current issue is with sheet to sheet connections.
Is there a way I can control how KiCad assigns connection names to nets that connect 2 different sheets?
For reference, I’m talking about this:
It seems to me that KiCad selects the suffix through alphabetic order.
Is there another way to control this in KiCad, besides changing the name of the sheets to influence this?
I’m fully aware, that I can force the net-class assignment by using directive labels and rule areas in KiCad 9.0.
