It’s been 4 days since the last nightly update. Do we have a known problem with the dev-PPA releases?
Same here (Ubuntu 20.04), I also report several issues that have been fix but I could check.
@Seth_h, ask me to avoid the reopen https://gitlab.com/kicad/code/kicad/-/issues/6091 on this cases.
There is a build problem at the moment due to our migrating the appdata files to be translatable.
This requires ITS rules that are not present with some of the Ubuntu build machines. @jsreynaud is currently looking into possible solutions. I believe that this affects Fedora as well.
Then I should return to breakfast builds
Just a heads up, the nightly issue has been resolved and the latest Ubuntu nightlies are current again
I also got a new nightly on my linux box.
Application: KiCad
Version: 5.99.0-unknown-886cad43bd~114~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-64-generic x86_64, 64 bit, Little endian, wxGTK, mate, x11
Date: Jan 27 2021 08:10:07
Boost: 1.71.0
OCC: 7.3.0
Curl: 7.68.0
ngspice: 31
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Weirdly, KiCad-nightly disapeared from the “start menu”, but it can be started from the commandline.
[Edit]:
The -nightly of both “kicad” and “pcbnew” disappeared when searching though the start menu. Eeschema is still present for both the stable and -nightly.
@imcinerney is this related to the metadata changes? Maybe it will be fixed with the next nightly with your latest changes?
Maybe it will be fixed, I don’t know for sure though. The Ubuntu Nightly package does some weird things to allow parallel installation.
@paulvdh can you report this in the packaging repo here please: https://gitlab.com/kicad/packaging/kicad-ubuntu-builder/kicad-daily-package/-/issues
Done:
The new release didn’t appear on Legacy Nighty Build ppa:js-reynaud/ppa-kicad
Did it was not triaged yet?
Don’t use the legacy PPA, use the new PPA here: https://launchpad.net/~kicad/+archive/ubuntu/kicad-dev-nightly
The legacy PPA is not supported or maintained anymore.
Thanks, I just imagined that was this…
Should be interesting remove the Legacy PPA information from the website.
To be clear: The legacy PPA is still maintained but is not recommended but new adding. When I’ll stop the maintenance, I will remove it to avoid future use.
I recommend to migrate to new PPA as description suggest…
I fix desktop file creation issue few minutes ago. Next build should be ok (in few hours).
