Hi Probably I am doing something wrong but I can not get rid of this track, updated the schematics, updated the PCB and still get this error: "Unconnected track DIG 2"Item I can see the white track line but connect to nothing. If I set a track goes to the end of the white line, does not connect to anything, but then there is no error in the “Perform design rules check”.
There is a “Target” symbol in the other side is there anything related? I can delete the symbol as well.
Any help is more than welcome
Using Kicad 5.
Can you share your board so we could check what’s going on?
Is it possible that you had some filled area here previously (but it should be gone after “DRC check”).
