I was able to snap graphics beginning and end points to other drawing elements like lines while drawing another line but right now I can not use this feature with nightlies. The only thing helping me is the grid. If the line is off the grid then there is no chance to cross the lines while drawing. I need to edit or move it manually.
[Edit:]
After turning on “Magnetic pads” in the Footprint editor, lines still do not snap to pads for me, which seems a bug, but I’m not absolutely sure I interpret that function correctly at the moment.
I’ll add it but I guess there is misunderstanding about this issue. What you’d reported is a clear regression, not a feature request as it still exists on stable branch (at least partially). Right now it is perceived as a low priority wish on the issue tracker.
Edit Note: I guess I need to create a new bug report for this regression.
Did you read the last comment there which I just added?
Please don’t report another issue, it would be handled as a duplicate anyway. Wrong categorization isn’t a reason to report the same problem twice. But you can add your comment to the old issue.
@eelik, haven’t seen your last message, here and as I had a problem with mixing different issues here in the forum, before, I’ve created another bug report on the tracker. Let’s wait for the developers decide whether this is a duplicate or not. Because for me this is a different issue than yours.
